It is currently Sun Mar 29, 2026 7:49 am
Post new topic  Reply to topic  [ 29 posts ]  Go to page 1 2 3 Next
PostPosted: Thu Sep 19, 2019 9:34 pm
This plane is gonna take me another week. I still have to do the rivets
for the fuse and everything on the wings needs to be done.
See more screenshots on my Facebook page soon!
PostPosted: Thu Sep 19, 2019 9:39 pm
found a zip file for a ebola 190 skin ..but its empty!
PostPosted: Thu Sep 19, 2019 10:55 pm
Thanks for looking. Ebola was one of the best!
Could the zip file need a similar year un-Zip program?
PostPosted: Fri Sep 20, 2019 7:10 am
Really nice sir!
How did you do it without the psd files?
PostPosted: Fri Sep 20, 2019 1:01 pm
I could tell you but you know I'd have to kill you .................. JK
I used the VFILE program and extracted the .tga files for fuse and wing from the current ppv/fw190d folder: fw190d_4.VFC. Red stripes are a bitch.
It is hard without the outline of the fuse and wing, so a lot of guessing where things are.
3 layers for Tan, Green and Brown. A lot of moving up and down until they are where they need to be.
I traced lines and rivets from the old skin onto 2 layers on my new skin.
It helps a LOT to be able to paint in Photoshop and save fuse and wing as .tga AND for the .planeskin command to work, sometimes it doesn't work.
Copy the targas into the skins/offline/Brown190 folder. Fly in Warbirds and notice whatever I just did in Photoshop. Adjust or make changes/repeat.
I'd say It has taken me about 12 hours so far (only for the fuse). The wing will take about the same. Sometimes I get lucky and someone has the old PSD files.
Check out my Facebook page and you can see before and after images of work on this fuse.
PostPosted: Mon Sep 23, 2019 11:01 pm
Here is the Brown version, I like it. I still have a lot
of work to go on the wings, so like I said, probably
another week to go.
I'm running out of space to upload images, so if
someone knows how to change this, let me know.
I think it's part of the Control Panel, but can't find
the place to increase my amount of images allowed.
Thank you for your tip, Robert.
Click on the image below and notice the cool
engine exhaust shadows, really adds 3D look!
Click on your "BACK" button when you finish.
PostPosted: Tue Sep 24, 2019 9:39 am
Really nice paint job, sir! Looking forward to using both of the "brown 4's" and the "yellow 10" :-)
I remember being told this forum has limited picture space allowance. I always use postimages.org to upload my pictures. The pics won't get removed for many years and it takes no space for the forum. Just copy the "Hotlink for forum" link that you get after uploading the picture and post it in the forum message. (Also just remove the second url if any, if you don't want to add promotion links to your picture)
https://postimages.org/
PostPosted: Fri Sep 27, 2019 8:47 am
A tip for you. For rivits I’ll use the path tool to make paths where the rivits go. Then I’ll set my brush to a dot shape and in brush setting set the spacing out a bit. So when I stroke the path, it makes a dotted line. You probably already know this but if not, it really helps.
PostPosted: Fri Sep 27, 2019 8:53 am
What’s VFILE ?
PostPosted: Fri Sep 27, 2019 10:04 am
No, I didn't know that about the dots. I'll try it out. Usually I make a dot
and select it, option-cmd and move it a number of pixels with arrows.
Then I repeat and repeat the copy-move until I have a line of dots. Then
I select the line and option-cmd and copy it to somewhere else.
Sometimes I make a tiny circle with selection tool and cmd-T it to make
it smaller. Sometimes I make dark dots, copy and paste them and make
them light dots side by side. This gives them a 3-d look.
VFILE is a DOS app that's proprietary to Warbirds. You have to sign a NDA
to use it. It opens up zero21_4.vfc files and such. It also puts the file
back together to add fuse.tga or fuse.dds, etc. If there is no Photoshop
artwork available, I have to open up the fw190dwing.tga and use what-
ever I can from that artwork. The fw190dwing.tga has no layers, it is
all one image, ouch.
