It is currently Sun Mar 29, 2026 3:16 pm
Post new topic  Reply to topic  [ 19 posts ]  Go to page 1 2 Next
 Post subject: Spit VC with 4x20
PostPosted: Sun Jan 27, 2019 10:22 pm
The spit Vc rolled out in fairly large numbers with 4x20mm. Wartime testing suggested that there was very little performance difference between that and the two x20 4x303 version. However, 2 of the 20mm were sometimes removed to increase performance slightly- I THINK- providing they were not replaced by 4x303 and all the ammo for them!
I'd love to see a SPIT V with 4 20mm, or the option of having only 2x20mm with no rifle caliber guns.
I can't remember the exact reasoning behind not including this variant- but I think it was people thought it would make the spit too good. I can understand that- but if that's the policy, then imagine the reaction if the most capable variants of the other planes in the game were disallowed?
PostPosted: Mon Jan 28, 2019 10:58 am
Interesting. I'll bring it up with the FM team and do some research. It would be quite easy to add the 4x 20 mm option to the Spitfire Vc for the next update.
PostPosted: Mon Jan 28, 2019 7:34 pm
PostPosted: Tue Jan 29, 2019 1:47 am
Jabo is 99% correct. It's a C wing on Spit V's. ;)
PostPosted: Thu Jan 31, 2019 1:23 pm
Something else for the FM group to think about. The description of the USA G-suit.
late model Spitfire IX also has G-suit systems installed.
PostPosted: Thu Jan 31, 2019 4:27 pm
PostPosted: Fri Feb 01, 2019 3:19 am
The back leaning seat for Me 109 was not very effective. In order to have any effect on G forces
the seat had to be leaned back to 65 degrees. Anything less then that has no effect. The Nazi
solution to the G problem was to install a metal bar just above the rudder pedals. The pilot put his
feet up on the bar and this would raise his legs up a little bit and slow the blood flow to his legs
and feet. And of course, it means that he couldn't use his rudder during high Gs. It raised the G
force a Nazi pilot could take up very little, maybe up to 6 gs. The Allied G-suit raised the G force
limit to about 6.75 gs and the pilot cold retain control of all the flight control systems.
PostPosted: Fri Feb 01, 2019 10:26 am
Any authentic links with these data / factual points?
PostPosted: Fri Feb 01, 2019 12:17 pm
Spit rudder pedals. Notice the two positions the feet can have. High and low.
http://spitfiresite.com/2010/07/anatomy ... static_001
Maybe .5G added to blackout resistance.
109 - Black 6 rudder pedals
http://109lair.hobbyvista.com/walkaroun ... .pedal.jpg
PostPosted: Fri Feb 01, 2019 6:13 pm
Finn
