It is currently Fri Jan 21, 2022 2:53 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2 3
PostPosted: Fri Nov 26, 2021 5:10 pm
You should be happy with the obvious advantages you have over everyone else and not complain about people doing what they have to do to avoid being one of your thirty + kills per flight.
mirlox wrote:
Please also check the trick used by many to ditch at high speed.
The so-called wing drag ditch.
In real FMs when a plane hits the ground with one wing immediately cartwheels and crashes.
With the actual FMs the plane just gently decelerates for a safe ditch.
PostPosted: Sat Nov 27, 2021 3:13 am
Mine just blows up, so there must be some other secrets in it as well. Sometimes they explode even when landing to a runway w/ too high speed.
PostPosted: Sun Nov 28, 2021 12:29 pm
Raksan wrote:
Robert, it's nice that things are getting done, but which version are we supposed to be using or expecting the updates for? Right now we have 2018, 2020, and 2021 versions all useable. However, the 2020 version says an update is available and will not download it. The 2021 version says an update is available, tries to download it, and says files are up to date even though it doesn't update.
Robert more than likely has no idea about which one is which to update. He's on the FM team and not the program team. ;) Stay with 2018 and all should be good. Shame they don't just put 2018 D/L up and just rename it 2020/2021 for now.
PostPosted: Mon Dec 20, 2021 2:25 pm
When can we expect mandatory updates? There are people that refuse to update so they can keep the BS over modeled 110. If updates aren't mandatory and anyone can fly any version of whatever plane they choose, why don't we all just get what we need to edit our own flight models and save Robert the trouble? It's not like everyone is flying the same version anyway.
PostPosted: Tue Dec 21, 2021 1:57 pm
The ability to use your wingtips to delicately drag and crash land has been in this sim since the beginning. It is not a flaw or anything that needs to be addressed. It requires a certain angle and speed and a delicate hand to pull off. Please refrain from telling us what happened in real FM's as you have never flown one and have no reference point to comment from.. except that when people safe ditch using this method it denies you a cheat kill.. BTW could you please delete your post that tells everyone how to download your cheat app so others wont be attracted to dishonest un-sportsmanlike play and then you can be the only one who knows how to use it?
PostPosted: Thu Dec 23, 2021 8:46 pm
I've asked for the post to be deleted a few times but it hasn't been. It doesn't matter anyway. The info is out there, it is obvious some are using it, and they'll just share it if the forum link is ever deleted.
