It is currently Sun Mar 29, 2026 3:36 am
PostPosted: Sat Dec 19, 2020 8:55 pm
As I've stated before: Jitter is a much bigger problem than ping times.
"What is jitter?
Jitter is the rate at which ping changes over a period of time (otherwise known as ‘ping spikes’ or ‘stuttering’). ‘Jittering’ is essentially the fluctuation or variation of latency over time. Simply put, if every information packet takes the same amount of time to travel from point A to point B, then there is no jitter. However, if the packet delivery times are inconsistent, then there is ‘jitter’.
In the same way as ping rates, the lower the jitter value for the connection, the better. However, consistency is the most important thing. You can adjust your gameplay to allow for lag and make timely, accurate shots. However, jitter makes for extremely unpredictable game play that throws off your timing making it hard to play successfully."
PostPosted: Mon Dec 21, 2020 8:42 pm
Yeah, latency is a curse. All of us players 'downunder' are already a day ahead of you guys, latency is the only reason we can't kill you before you even get out of bed! :roll: :lol:
PostPosted: Wed Dec 23, 2020 1:32 pm
Mackar wrote:
Yeah, latency is a curse. All of us players 'downunder' are already a day ahead of you guys, that's the only reason we can't kill you before you even get out of bed? :? :? :?
I thought it is because you hang head down there and we are flying under your heels... :shock:
