It is currently Sun Mar 29, 2026 3:20 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2 3
PostPosted: Wed Apr 10, 2019 8:30 pm
The Russians love the M4 but it does not reference very well against others
http://users.telenet.be/Emmanuel.Gustin ... un-qa.html
Interesting documents for W2 50cals. Often people quote modern 50cals with different ammo.
http://weaponsman.com/?p=7750
references this
http://www.lonesentry.com/blog/length-o ... nners.html
lots of gun stats here
http://users.telenet.be/Emmanuel.Gustin ... un-pe.html
Aircraft moved away from 50cals. There was a reason.
PostPosted: Thu Apr 11, 2019 1:17 am
Yes there was a reason. The evolution of weapons combined with the size of the target and vulnerable areas available the target has. Experience is a great motivator to advance evolution. Emmanuel Gustin has a good page that has tables of MV, ROF, weight of gun, etc. with some other interesting pages like this one.
http://users.skynet.be/Emmanuel.Gustin/ ... un-fi.html
It also involves the type of mission said weapon platform is going to be involved in. To take down heavy bombers you needed 20mm or better yet 30mm guns in WW2. HMG just isn't going to be the weapon of choice for that type of mission. The .50 in a battery of 6 or 8 will be effective against piston engine fighters, light bombers and light ground targets. The .30 size rifle guns were basically just a weapon against fighters which is barely of use against a heavier armoured fighter let alone a light bomber.
Large WW2 era bombers and as aircraft became larger with less areas that have a very vulnerable spots is one. Turbines replacing piston engines helped the .50 to be pushed by the wayside. No coolant system, much smaller, less vulnerable fuel system around the turbine, and more resistance of damage to the turbine from HMG rounds, which made the move to explosive cannon rounds mandatory in my mind..
Another is more power to hoist more weight along at higher speeds. A prop fighters of WW2 era could only carry X amount of weight, so you get fewer heavier guns with heavier rounds with less rounds available or more guns with more rounds being able to be carried. Adding in the variables of gun performance also helped in the choice.
Fuel switching from avgas to jet fuel. One doesn't flash fire so good and combat at higher altitudes where both didn't burn little if at all. You need oxygen at the right level for combustion.
I'm sure there's others, but these are at the top of the list i my book.
PostPosted: Thu Apr 18, 2019 7:57 pm
With the new mini update the P-39's 37 mm M4 cannon has had it's damage increased from 30 dmg/round to 40 dmg/round. A normal 20 mm cannon does 7-8 dmg/round. Most fighters have a fuselage/wing/stabilizer toughness of 41-50 hitpoints. As such the M4 cannon has been raised to 40 dmg to avoid constant one ping kills, as that could be detrimental to gameplay. Only some of the more fragile fighters like the A6M, Ki-27, Ki-43 etc will be destroyed by a single M4 cannon shell. Still since the M4 cannon now does 40 damage, you'll usually only need a single M4 hit + a few machinegun bullets hitting a fighter in the same spot in order to down it. Also at 40 dmg/round not even the tougher fighters can withstand two M4 cannon hits into the same part anymore.
PostPosted: Thu Apr 25, 2019 10:10 pm
Well done Robert! I had a go in the p39, and it's much better without being a game buster.
