It is currently Mon Dec 08, 2025 11:57 am
PostPosted: Fri May 15, 2020 9:47 am
Might as well start one in case anyone from ient reads these forums
1)The toggle switch for the hud is backwards; off is on and on is off
2) Pressing the update button shuts down the game without any sign it's looking for an update or message that I already have the latest version.
PostPosted: Fri May 15, 2020 12:50 pm
That is not a "check for updates" button, it is an update initiation button. Updating dumps you from the game, because it can't update while the software is in use.
PostPosted: Fri May 15, 2020 8:27 pm
I'm sure that makes perfect sense but I'm a little confused by it. Not unusual for me these days :) Doesnt it need to check for an update before it can initiate it?
PostPosted: Sat May 16, 2020 2:24 am
If there is an update, when you log in the game will ask if you want to check before you can enter an arena. If mandatory you will have to run the updater before you can get in. At any rate, you cannot update, "on the fly", so to speak. No pun intended.
PostPosted: Sat May 16, 2020 10:21 am
Understood. Thanks for the explanation.
