It is currently Mon Dec 08, 2025 11:13 am
Post new topic  Reply to topic  [ 15 posts ]  Go to page Previous 1 2
 Post subject: Re: next update
PostPosted: Fri Feb 09, 2018 5:00 pm
Pakrat you were fairly correct about the Yakovlev series maneuverability. They were among those FM's I modeled based on Power OFF stall speed data. This has been fixed now with update FL2054 (see separate post for details), and the Yakovlevs now stall at an ~8 mph IAS lower speed, meaning they can turn and maneuver better. They will still not flip like A6M Zeros but are definitely more competitive than before.
The new Yak-9U flightmodel is now finished and waiting to be released. This Yakovlev version has a much improved max dive speed (447 mph) compared to the older Yak's (404 mph). Also due to Frise type ailerons it retains it's roll rate better at higher speeds. Service ceiling is 35000 ft and it is 168 lb heavier than the Yak-9D and 1094 lb heavier than the Yak-3 (which had smaller wings though). Maximum speed is 366 mph at S.L. and 414 mph at 16400 ft, which is very close to the numbers in the Russian Yak-9U Pilot Handbook (366 and 410 mph). Other Russian tests claim 359-363 mph at S.L. and 418 mph at 16400 ft. It is also better than the other two Yak's in a sustained turn due to it's improved power/weight ratio.
Below is a comparison of the Yakovlev models vs the P-51D and new Spitfires (which will soon be released fully remodeled in the coming FL2055 update).
PostPosted: Fri Feb 09, 2018 10:31 pm
I've been working feverishly on a new skin for the Yak 9U,
so because of you I've got paint all over my face, hands and
on my new black jeans. When is the cutoff date for this skin
to be in the new update?
PostPosted: Sat Feb 10, 2018 8:37 am
Hehe thank you Iart7, and your work is more than appreciated. Probable release date is during next week or at latest the week after. Take your time though as we can always use a Yak-9d skin until you are finished. Better to make it good than making it fast ;) .
PostPosted: Thu Feb 22, 2018 8:47 pm
The huge FL2055 update is nearly finished and will be sent in to Ient at Monday next week. It should be released shortly thereafter.
PostPosted: Sat Feb 24, 2018 12:56 pm
Yes indeed it is a large update !
New FMs for selected planes
New plane variants
New default skins
New and revised PPV skins
Bug fixes
Terrain updates
