It is currently Fri Jan 16, 2026 11:58 am
PostPosted: Tue Nov 21, 2017 3:05 am
Hi all, having 2 issues and can't figure out how to fix it. I was discoed out of the S3 the other day, when I finally got back online, my views now uses the pilot head acceleration due G forces when I look around, in that the head movement (or view) is slow and rotates slowly around rather than snaps around when I release the hat view button. I have not checked the box for that option, it isn't currently "ticked", in fact I've tried selecting it to see if its backwards or something, but no joy. I've tried logging out, restarting, updating etc and I simply cannot find the fix. Today, I tried to access the help button and it kept telling me that help was already displayed, when it wasn't. I don't like the feature and am hoping there is some setting I need to change rather than a complete download. While I'm at it, teamspeak now isn't working for me either, in that I can't hear anyone but apparently I can transmit and others can hear me....it all happened when I got discoed so does that somehow mess with settings?
Cheers all
Knuckr
PostPosted: Tue Nov 21, 2017 7:18 am
Shift + P
toggles between snap views and scroll views
PostPosted: Tue Nov 21, 2017 1:24 pm
Forum Admin
Shift + P for snap views
Shift + O for virtual views
Cycle these two a couple times.
If that don't work try this:
Go into your main WB directory and find the file "gfx9set.cfg" and delete it. Then run the updater again.
If that still does not work then try this:
Open WB main directory
Open Settings folder
Open setup.cfg
Scroll to the bottom
Find the setting for HEADSHIFT (Should read HEADSHIFT 0 or 1. 0 is off, 1 is on)
Change the value to a zero
Save file if you changed the value
I hope one of these will help.
+CHUNK
Forum Administrator
yblast20@yahoo.com
PostPosted: Tue Nov 21, 2017 6:57 pm
Thanks guys, Ill give them a try and let you know.
Cheers
PostPosted: Wed Nov 22, 2017 6:30 pm
Thanks guys, fixed it with your help!
PostPosted: Thu Nov 23, 2017 4:29 pm
Forum Admin
Glad to hear!
+CHUNK
Forum Administrator
yblast20@yahoo.com
