It is currently Mon Dec 08, 2025 2:06 pm
Post new topic  Reply to topic  [ 14 posts ]  Go to page Previous 1 2
PostPosted: Sat Oct 21, 2017 2:35 pm
<Robert>, the previous reply about wifi is the first I believe I've ever heard with that thought. These days there are so many devices that use wifi that it should be an obvious response. Can we hear from other players who might have more info?
PostPosted: Sun Oct 22, 2017 6:48 pm
Now-a-days in WB's I believe the parameters for connection to the server have been loosened up quite abit. Remember 3-4 years ago when most folks with round-a-bout connections couldn't keep in the game and pretty much couldn't get 15-30 mins on before disco.
I'd say good number of disco issues now are from something auto-updating. I turned off all auto-updates for everything I could find.
My problem now is it appears the ati drivers (RX480), windows 10 or WB's don't like each other. Since no other program has an issue with the drivers; I'd say something is missing. I can only find DX11. Wonder if that's my problem?
PostPosted: Fri Nov 17, 2017 8:27 pm
Thanks for the additional replies and about using the cable, Grumpy did you find anything else out and solve your issue?
PostPosted: Fri Nov 17, 2017 11:19 pm
Yes I did. The newer drivers for the r series are flawed it seems. It locked my GPU and Memory at 300 MHZ!!! Scoured the web and found people saying frame rates were doing just as what I experienced. Backed off to the drivers from 2 years ago and everything good.
I also had to add MSI's program for video cards to get the VC's fans to work properly. I only loaded the basic driver.
When I get a chance I'll post what I did in the Windows forum. Very busy at the moment.
