It is currently Fri Feb 27, 2026 4:01 pm
Post new topic  Reply to topic  [ 29 posts ]  Go to page 1 2 3 Next
PostPosted: Wed Sep 06, 2017 7:27 am
Lots of speculation on whether the A6M2 had float type carb or not that cut out under neg-g manouvers.
When the USA rebuilt and tested the A6M2 in WW2,
it is claimed that they must have installed the carb incorrectly, so this is why it cut-out.
Do you have anything concrete to substantiate either way ?
PostPosted: Wed Sep 06, 2017 2:33 pm
In all my readings over the years (decades), I do not recall ever reading that any Reisen model had a similar cut-out issues like the early Hawkers.
I will do some searching and post back with references.
Is there a reference for this? The TAIC report on the Akutan zero does not reference this, If I recall correctly.
EDIT: - Previous Thread on this topic:
http://forum.totalsims.com/viewtopic.ph ... 9&start=15
PostPosted: Wed Sep 06, 2017 3:15 pm
https://forum.warthunder.com/index.php? ... arburetor/
Check out Kitsune's post. He talks about a down-draft float carb that prevented neg-g cutout. Sakae 21, I think
PostPosted: Wed Sep 06, 2017 4:57 pm
sure. no question on the A6M3.
PostPosted: Wed Sep 06, 2017 5:17 pm
Also for our anyone who speaks Japanese:
How would you write these words in Japanese (with English letters)?
Power for lift off = ?
Take-off power = ?
War emergency power = ?
Rated Power = ?
Military Power = ?
Nominal Power = ?
Maximum continuous power = ?
Or what words did the Japanese use for these boosts settings?
Cheers and hopefully we shall soon see fully revised A6M's in Warbirds :) !
PostPosted: Wed Sep 06, 2017 6:43 pm
Robert some of what you want is here.
https://drive.google.com/open?id=0B-ehX ... WZ0dDRkSUU
PostPosted: Wed Sep 06, 2017 7:42 pm
Ty sir, it's only in Japanese letters though, need Japanese translation in English letters (game can't handle other symbols in the HUD). Not sure if I dare to fully trust Google translate.
PostPosted: Wed Sep 06, 2017 8:32 pm
OK - Ive checked the following resources:
IJNAviator1937-45
RAAF Directorate of Technical Services Detail No. 119/A/30 for the MK. II (HAP) [A6M3 for our purposes]
JICPOA 5981
Curtiss P40C vs. Model 21
Spit Vs. Zero - A.L. Walters Group Captain, No. 1 Fighter Wing, RAAF - Darwin
J-Aircraft.com
Warthunder
WWII Aircraft Performance
Wiki
And several other sites using various queries like Sakae 12, Sakae Development, Mitsubishi Engines and other terms.
Conclusion:
There are no easily found documented anecdotes stating the SAKAE 12 engine suffered from cut-out in negative G maneuvers. Compare this to the fact that the Hawker engine cutout is widely documented and cited. The absence of even one resource citing a negative g cutout makes me think that it was not a characteristic of the down-flow carb.
I do recall, within the last four or five years, seeing a diagram / animation of a schematic carb with the neg. g. issue, versus a downdraft version. I will continue on with this...
EDIT - This YT Video also does NOT mention negative G cutout - where if it was a characteristic of the Zero, they would have mentioned it...Certainly.
https://www.youtube.com/watch?v=teXzEti5PVY
Still reading this:
http://www.wwiiaircraftperformance.org/ ... -dec42.pdf
PostPosted: Thu Sep 07, 2017 12:29 am
So this Intelligence Summary 85 from December 1942 mentions Neg G cutout for the SAKAE 12.
However, there are several sites and forums that state the initial tests had the carb installed incorrectly in the Akutan Zero. I do not know if this report was the one made with the alleged incorrect positioning carb.
Of importance to note - Nakajima designed the downdraft carb for the SAKAE 21 (If I am remembering this correctly...read a lot of this shit tonight).
Also to note - the SAKAE was the IJN version of the HOMARE for the IJA. Again, if I remember this correctly.
EDIT - I cannot upload a pdf...so give me a day or two to get this uploaded.
PostPosted: Thu Sep 07, 2017 1:41 am
Early Japanese aircraft engines used float carburetors. That means they were susceptible to neg-G fuel delivery problems. It would take a pressure type carburetor to prevent a power loss in neg-g situations.
This report on the Sakae 12 engine say it has a float type carburetor.
http://www.wwiiaircraftperformance.org/ ... ort-24.pdf
This report states the A6M2 does have neg-g problems.
http://www.wwiiaircraftperformance.org/japan/p5016.pdf
FWIW
Users browsing this forum: No registered users and 44 guests
