It is currently Fri Apr 17, 2026 4:57 am
 Post subject: Exit URL help.
PostPosted: Mon Sep 20, 2021 9:52 am
Where the hell is it hiding these days? Windows 10, can't find the bloody thing to delete it. Been through every file I can open, ran searches and they come up, no matches.
In the top five most aggravating, stupidest, scripts ever conceived.
 Post subject: Re: Exit URL help.
PostPosted: Tue Sep 21, 2021 12:06 am
Open the file named "quiturl" in WarBirds 2018 folder with notepad or something, delete what's written, save and close. Be sure not delete the file itself.
PostPosted: Tue Sep 21, 2021 3:07 am
That's how I used to do it. No such file or text to be found in any folder, been through every one manually and via search. Makes no difference if the hidden files option is checked, or unchecked.
As Rodgers and Hammerstein wrote, "Tis a puzzlement"!
PostPosted: Tue Sep 21, 2021 7:23 am
My guess is that you accidentally deleted the file. Reinstall the game then it should be there.
PostPosted: Tue Sep 21, 2021 7:52 am
Don't bother reinstalling. Just create a text file in the WarBirds2018 folder and name it "quiturl"(leave it blank).
PostPosted: Tue Sep 21, 2021 10:46 am
Obviously the file is there, somewhere. It runs every time I exit. But Windows can't find it via UI searching or command prompt, and I can't find it manually looking at the files.
Putting a new file in as you suggest changed nothing.
This is a fresh install, within the last month or so, of both OS(W 10) and WBs. Didn't even look at the folder until I went to delete "quiturl" and couldn't find it. Ran the updater and show all files up to date, and still no "quiturl" to be found.
PostPosted: Wed Sep 22, 2021 11:13 am
Mine's not in one of the sub-folders. I find it in the long list of stuff under the sub-folders in the WarBirds 2018 folder.
Hope that helps.
PostPosted: Sat Nov 27, 2021 7:33 pm
I just alt+F4 to leave the game. I couldn't find the file either.
Users browsing this forum: No registered users and 39 guests
