It is currently Sun Mar 29, 2026 4:59 am
PostPosted: Mon Jun 08, 2020 4:25 pm
What is the point of these items? all they do is reduce framerates and make it harder for certain users to see targets etc. The trees are useless as you can drive right thru em and they arent the same on everyones front end,, so if I think i'm hiding under a tree after driving 10 minutes to try and defend a base in an SDK the attacking con sees me in the clear while I should not be visable.... Same for clouds. Until they are synced and consistent for all they should be eliminated for gameplay sake. The clouds especially.. they suddenly come on out of nowhere, hang around for a few minutes and then whoosh, gone.. What purpose do these serve and why use them at all? Just turn em off and make it better for all until they are fixed. Also, it looks bad to newbies who have asked whats the deal> It gives the impression of an unfinished badly coded sim.... Please flip the switch..
Thanks..
Le Rat..
Edit... or at least put back the dot command to let the user toggle the clutter and weathereffects that we used to have but was removed for some reason..
PostPosted: Thu Jun 11, 2020 6:08 am
Thanks..
Le Rat..
If trees were the same for everyone, I'd like to have them. Junior tried Legacy tanking last night and told he was once killed by invisible enemy through a forest. Well, he went to lumberjack mode then and said it was easier.
