Update FL2070: Heroes of Midway
http://bhlanding.ient.com/warbirdsforum/viewtopic.php?f=8&t=564
Page 1 of 1
Author:  Robert [ Thu May 30, 2019 7:50 pm ]
Post subject:  Update FL2070: Heroes of Midway
---== UPDATE FL2070: Heroes of Midway ==---
By: Robert, Grumpy, Bollok, Sleepy & Jabo.
--= SBD-5 Dauntless =--
This update brings a rehaul to the Dauntless dive bomber. It has been fully remodeled and should now quite closely match real ww2 performance. See further down for details.
--= TBF Avengers =--
Small torque reduction for the TBF-1 and TBF-1C. Minor defensive gunner accuracy fix for both Avengers.
--= Ju-87 Stukas =--
Defensive gunner accuracy fix for the Ju-87D and Ju-87G. The -D rear gunner previously fired in a too steady line while the -G rear gunner had to large dispersion.
---== THE DOUGLAS SBD-5 DAUNTLESS FULL REHAUL ==---
The SBD (Scout/Bomber/Douglas) Dauntless dive bomber was very well fitted for it's role in the Pacific Theatre, and was an important leap in performance compared to the earlier TBD Devastator. Not only did SBD's sink several Japanese carriers at Midway, but they also supported the infantry in various operations and made a surprisingly good account of themselves against Japanese fighters and bombers alike. The SBD pilot and his gunner, Leppla and Liska, became famous for shooting down seven japanese Zeros/bombers in two days. In the Coral Sea encounter USN planes downed 91 Japanese adversaries, 40 of those were shot down by SBD's. The SBD was often unofficialy named the SBFD, the "F" standing for Fighter. While a single Dauntless doesn't have the speed or roll rate to really duel a dedicated fighter 1v1, a group of them can definitely defend themselves against A6M Zeros thanks to the SBD's ruggedness, defensive twin .30 cal machine guns, 2x .50 cals in the cowl, and surprisingly good turn rate. The Dauntless has a wingloading of only 28.9, lower than a Spitfire IXe, but lacks somewhat in power/weight ratio compared to real fighters.
The area where the Dauntless shines though is dive bombing. It can start it's dive from above 20 000 ft, and has dive flaps to help regulate the airspeed. The max permissible speed is as high as 425 mph (IAS), which makes it harder for enemy fighters to intercept the bomb run of a SBD. The payload is decent but the ammo for strafing is quite limited. The chance of surviving the sortie and fighting back against interceptors is impressive though for a single engine bomber, and the Dauntless earned a good reputation in the Pacific Theatre.
Comparisons with other remodeled single engine bombers
Author:  iart7 [ Sat Jun 01, 2019 12:29 am ]
Post subject:  Re: Upcoming Update FL2070: Heroes of Midway
I don't know why the IL-2 and Ju-87D would be flying at Midway, but here is my skin for the Stuka and Avenger:
The attachment Stuka 23a_med.jpg is no longer available
The attachment Avenger Sun1_med.jpg is no longer available
Author:  Robert [ Sun Jun 02, 2019 6:10 pm ]
Beautiful skins!
The Stuka and IL-2 are only in the charts for comparison with other single engine divebombers, sir. The title of the update refers to the SBD Dauntless :).
And the next dive bombers to be updated this summer will be the TBD-1 Devastator, B5N2 Kate and D3A1 Val. The current TBD-1 Devastator will be quite different once remodeled. I'm now working on the TBD and discovered that the current flightmodel is nearly 100 mph to fast and climbs way to good. Seems the last programmer gave it an engine at ~2100 hp. Not bad for a 1937's torpedo bomber :lol: . Not even the late war TBM-3 Avenger had that beast of an engine. The correct engine setup for the TBD's Pratt & Whitney R-1830-64 Twin Wasp engine is 900 hp at S.L. and 850 hp at 8000 ft, which is quite a difference. This will mean quite a nerf to the TBD-1 speed and climb rate compared to what we have now, but the actual handling and wing efficiency etc will be better.
Page 1 of 1 All times are UTC-04:00
https://www.phpbb.com/
