It is currently Sat Jun 23, 2018 3:53 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: Hope For Help;-))
PostPosted: Wed Mar 01, 2017 1:52 pm
<S> Net
Great to see u back in the game sir.
WB wasn't same without you.
Glad you were able to get things to work. Look forward to more missions with and against you.
PostPosted: Wed Mar 01, 2017 2:08 pm
Can't remember where I found this a pop-up window for legacy joystick, but it asks you what is the primary joystick or something similar.
PostPosted: Thu Mar 02, 2017 7:54 am
Howdy Swan & Grump;-)))))
"Target Drone" Will Be Back Soon!;-)))) Hopefully Draging The Enemy To Their Death.
I Stab Them You Slab Them !! HeHe... I Can't Shoot For $hT...But Love Drag'n Them Fools!;-)))
PostPosted: Thu Mar 02, 2017 8:37 pm
http://www.jg-51.com/topsecret/ST_SD7_0 ... ftware.zip
Net
The above link is X52 software if you might need it. The zip contains 64bit software and application for controller programs along with a manual. It's there if you want it. 100MB download.
I use the X52 on 64 bit and windows 10 and have no issues I see you are having.
I hope it helps.
PostPosted: Fri Mar 03, 2017 6:34 am
Thank you Dr.D
Will try it
Will i need to load Net ver 3.5 Hate to mess with things to much.;-)))Ps; that download from Madcats/Saitek said i needed it?when i tried to download driver.
My loading of 10 was a nightmare/;-))my fault ?
Heck that Gates likes things his way.hehe
Tried to uncheck things in windows and then got a message could not use Amazon music... reload it worked fine!
TIA Dr.D...NetNut
PostPosted: Sat Mar 04, 2017 6:56 am
Howdy
Installed that software driver , also it installed the net 3.5 thingie.hehe ect. Still a no go. Throttle works when testing it in set up. But in game no go!
Still using the thumb slider on throttle it works like handle.
Oh Well
Thank you all;-)))
NetNut
PostPosted: Mon Mar 06, 2017 12:04 am
Is there anyone else nearby that has a joystick (not necessarily the same stick) that you can borrow?
Game: Warbirds 2016
Getting ready for Orange Jumpsuit: Hillary
PostPosted: Wed Mar 08, 2017 6:30 am
Howdy iArt
I like it this way now;-))))) need to get used to it.hehe little slider works good for throttle.... makes me play smoother... i don't yank on controller as much.
Thank you have a Great Day!..... NetNut
PostPosted: Fri May 19, 2017 5:43 pm
netnut wrote:
Thanks Everyone
Got a work around. The slider on the throttle stick works the Gas. So That Will Get Me Going, If I Can Pass The Check Ride!
Will Try To Assign The Slider, Back to main handle,If I Can!!!!Don't think so?
Any way the slider will work for now!!!;-))))
Nut did you ever figure this out, I have an x 52 win 10 and my throttle did the same thing its a simple fix hopefully, once you do it in the WBs mapping setting. Let me check it out and I'll get back to you. Sorry to hear about your health.
Just got back into the game a tad, had arthritis it hurt to use the JS, so I stopped for a year. Just found this board.
I'll send you a PM if I can...
PostPosted: Sat May 20, 2017 1:58 pm
Don't stir the stick in circles so much and it will help with the arthritis!
Sorry olddog I couldn't resist. :mrgreen:
Good to see you back.
