It is currently Sat May 21, 2022 8:24 am
PostPosted: Tue Jan 25, 2022 4:47 pm
For those who don't know about the S3's or haven't tried a frame or 2 on for size; Wilz has this posted over on the S3 forum. Not truer words said and I'm sure he won't mind me posting his message here. Visit the S3 forum and announce that you'd be interested. I'd suggest logging in 8:00 - 8:10 PM EST.
Link to the S3 Forum General Page: http://www.squadselectseries.com/s3forum/viewforum.php?f=1
BTW, and I'm sure Muzz would concur. A lot of players are missing out on not showing up to fly on Sunday night.
It's not the usual game play, planning and strategy are paramount to win the objectives. Come a little early, log on,
and see how you can fit in. The S3's will challenge you more than normal game play. Get on Teamspeak and work
together for a challenge you won't find in everyday play.
=wilz=
PostPosted: Sat Jan 29, 2022 1:09 pm
Update for this Sunday Jan. 30th. Go to the S3 Forum using this link for the map and more details:
http://www.squadselectseries.com/s3forum/viewtopic.php?f=1&t=3704
Frame start 2030hrs EST, Sunday 30 January 2022
Log in early!
GENSIT: Axis troops are rapidly retreating towards Stevastopol with Soviet Armoured columns close on their heels. The Gneisnenau Line was a hastily thrown-up defensive position centred on the road and rails lines running through Simferopol and extending to the sea. As rapidly as it was occupied by the Axis, it was abandoned for the stronger defences at Stevastopol. A few axis troops and armour were left behind in a delaying action. The Luftwaffe has abandoned almost all its forward airfields and is operating from within the Stevastopol perimeter (F28). Airfield 256 is available for aircraft to land and re-arm, but pilots may not start the frame there. On the VVS side, the Soviet ground advance was too fast to allow the VVS to operate from recently captured axis fields. Airstrip 213 is open, but flight is not enabled there.
Axis(LW) – Gold
Allied (VVS) - Red
Side assignments (see series info post). 13 VRAF should remain on the Soviet side. Depending on 352nd turnout, RCAF may join the axis for side balancing.
Comms - Axis should share the 4th FG channel on the iEN TeamSpeak server. Soviets should share the 352nd's channel.
Terrain – Crimea. Fields not tactically relevant to a frame will be set neutral or hidden. Airfield 181 will be set purple for initial arena log in.
Weather – clear.
Time - 0630hrs local time
Radar – 5 miles, min altitude 10 feet.
Max Flak Alt – 30,000ft
Objectives:
LW – Maul the advancing Soviet columns and protect axis defenders from air attack.
VVS – Destroy Axis troops in defensive positions. Close airfield F257 to further restrict Axis air power.
